Is there a way to have 2 audio sources being sent out the the speakers at same time?
Dagostar
Dagostar
Hey there,
I have a Yamaha HTR 5460, and I'm wondering if there is a way to have a microphone plugged into the receiver, and have the audio from the mic sent out the the speakers at the same time that audio from a DVD player is also being sent out to the speakers?
In a nutshell, can 2 separate sources of audio be sent to the receiver and then sent out the the speakers concurrently?
Thanks in advance,
-Dagostar
adwilk
adwilk
I would get a mixer, that will allow you to hook up multiple sources, especially a microphone, and then output to your receiver.
Most HT receivers won't really handle a microphone and certainly won't allow you to play multiple sources at a time without a device in the middle (mixer)
This would probably work just fine...
Knucklehead90
Knucklehead90
Or use a computer. Play the DVD at the same time as you are using the mic plugged into the sound card.
