Is there a screen paint that is tried and true?
BoomDog28
I want to paint my screen. I'm currently projecting on a griege color and honestly it's not bad and I wouldn't even bother if it didn't get marked up by accident during room construction. When I tried to touch up the spot, I now clearly see the lines from the roller of new paint next to old paint. Before I go out and buy paint for a fresh over haul, I was wondering if there is a paint color/brand that has established itself as the go to for screen paint. I think I would prefer a grey tint over white since I sit so close and projector is bright. The slight dim is easy on the eyes and blacks look black.
BMXTRIX
BMXTRIX
While I hate doing so, I recommend you check the DiY section for screens over at AVS Forum. Things get very thick there, but they have a ton of DiY screen information with lots of options. Of course there isn't one 'right' solution. There are tons of choices and you can really just decide for yourself. They will all be decent if your wall is good.
