Most TV CRTs seem to degauss when turned off long enough and then turned back on. You can usually hear it when it happens. Make sure to leave the TV off long enough for it to no longer be in a stand-by state (remove the power cord if you have to) before turning it back on. Sometimes it will take multiple attempts, but make sure to space them out over a certain amount of time (off for half an hour or so is more than safe) so as not to damage anything.
My (brand new, at the time) Toshiba 27" CRT started turning blue in one of the corners. I turned it off for about an hour (got distracted
), turned it back on and it was all better. It hasn't happened since.
If you're lucky you'll find a manual deguass function, but I've only seen those on SVGA monitors. There are external degaussers you can purchase as well, but they're trickier to use (and don't have good results on certain problems).
If it doesn't appear to be getting any better (or you really want that new TV
), the solution is probably something harder.
