Hey everyone, i've owned a few subwoofers and currently have a new setup that i'm pretty happy and confused about. I'm really trying to make my system sound more "crisp" and hit the lows harder (for a cheap sub at least).
Here is the subs box and amp setup that i paid 250$ used from craigslist; which i found to be a great deal. All my wiring gauge is correct i know for sure.
-Alpine CDA-105 headunit
- 2 12" kicker comp subs in ported kicker box at 2 ohm(kicker 10dc122)black and yellow pair:
Peak: 600 watts per system / 300 watts each sub
RMS: 300 watts per system / 150 watts each sub
Sensitivity: 100db
Frequency: 27-500 Hz
Ported box specs:
Width (inches) 32-7/16
Height (inches) 16
Depth (inches) 17-9/16
- Alpine (V-power) mrp-m500 mono power amplifier:
300 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
variable low-pass filter (50-200 Hz, 24 dB/octave)
variable bass boost (0-12 dB at 50 Hz)
subsonic filter (15 Hz, 24 dB/octave)
speaker- and preamp-level inputs
fuse rating: 30A x 2
The amp is clearly bumpin both my subs no problem but i'm still confused on how to set my amp or if i should use another amp. Any ideas on settings of the amp? here's what i can choose from on the amp itself.
gain: (min - - normal .5v - max)
Bass Eq: 0db - 12db
lp filter: 500-200
Help me not look stupid!
Cheers and thank you all for reading!
