jgw4
I have a PSB image 6 sub thats about 8 years old. It appears to be almost dead. There is zero sound from the sub. Checked the power source, have power. Checked the fuse, filament intact. When the off/on switch is toggled to ON, the green power switch lamp is not illuminated. Also, when powered on/off, I hear a tiny electrical "whoop" sound for a split second. Any suggestions or other diagnostics?
Adam
Adam
Are you sure that it's the sub and not that there's no audio signal being sent to it?
annunaki
annunaki
Moderator
Sounds like it could be a power amplifier issue. Remove the woofer for inspection & testing. If it checks out fine the problem most likely lies there. They power light not coming on does seem to be the obvious clue though.
