O
OffRoad322
Hi all,
As you may be able to tell, I am brand new to the forum. I've been searching around for a while, but haven't found an answer to my question.
My Current Setup:
- Amp: Sony STR-DE695
- Fronts: Boston VR1's
- Center: Boston VRC
My question is simple, is my amp enough power to take care of my fronts and center speaker? I would like to add a 8" - 10" subwoofer, will it power that enough?
Also, (I know wrong forum, so I will post here and in sub forum) what sub would pair well with my setup.
Thanks for the help.
Adam
Adam
OffRoad, welcome to the forum. If you get yourself a powered sub (one that has a built-in amp), then the receiver won't have to supply any power to the sub. Those are very common these days.
O
OffRoad322
Thanks for the reply and the welcome Adam.
Two follow-up questions though:
1) What brand subs do you recommend for my room that is 21L x 14W
2) Is my amp underpowered for my speakers? VR1's and VRC Center?
E
edmcanuck
1) SVS and HSU are the leading candidates. Get 10" as that's a good sized room.
2) No. Those speakers are easy to drive (8 Ohm) and ridiculously high efficiency (93dB/1 watt/1 meter). They could be easily driven by just about anything. That said, you won't find much love for Sony products around boards like this where people know better.
Seth=L
Seth=L
While Sony is not the favorite among quality audio products it will power those speakers fine to possibly irritating levels.:D
sholling
sholling
Welcome to another Boston fan!
I concur with SVS and Hsu. My advice is to email SVS and have them size a sub for your room. Their customer service is first rate. They will need the cubic feet of the room and any spaces that open into the room. A diagram with dimensions will help a lot.
Oh and while looking at their 10" subs take a peek at their 12" subs as well. :D
