Sounds Like You Are Looking For A DIGITAL receiver
Sn1ck3rz said:
I can't seem to find any information on how to determine if an A/V receiver has the ability to be used just for the remote controlled input switching w/o running the amps. My wife rarely wants to have the amp on when she is using it just for her but would appreciate not having to get up and push the buttons on my passive A/V selector device. I want to upgrade to a receiver that can handle all of my inputs so I can chuck the A/V selector but the wife doesn't want the heat and added energy drain of the A/V receiver when she only needs the regular audio output from our television.
From the criteria you have listed in your later posts you want to go to the new Panasonic digital receivers such as the XR-57. They are small, lightweight (less than 10 pounds), have all the switching (HDMI etc.)and power (100 watts X 7) you will need and run as
COOL as a cucumber. Audio quality is as good as any.
I did a direct side by side comparison to my Yamaha RX-V1400 for several weeks and found absolutely no difference in sound quality between the two (actually I used a Panny XR-55 which is virtually the same as the XR-57 with less switching).
