I'm thinking about adding some sort of tube unit to my setup to get some of that tube warmth and such. I don't want this to turn into one of those "tube vs. solid state" debates. I am fairly well versed in the tube vs. ss debate, am aware that a tube amp will likely sacrifice a little bit of clarity for warmth, have heard the difference that tubes can make as a guitar player, and am pretty convinced that tubes would improve my listening experience and reduce ear fatigue.
At this point, I'm testing the waters to see if I really have any options here. With guitar gear, tube tone can be had (or added to a rig) without spending thousands of dollars. I don't know if it's that feasible with home audio. Maybe tube circuits that are designed to not color the tone are significantly more expensive.
I don't have a set price point at this point, as I am testing the idea out, but I am thinking in the low hundreds, the lower the better. I am quite willing to buy used gear (that's what I did to get my current setup).
My current rig is:
-Computer as a source
-Onkyo tx-905 stereo receiver (got it for $50 shipped on eBay - a steal)
-Bic Venturi DV62si speakers (2-way bookshelf speakers)
I don't suppose there's a way to keep the Onkyo in the chain, is there? I don't particularly care for the radio or tone controls on it (I found out that I could bypass the tone controls and have left it that way since and used the EQ from iTunes). I'm wondering if there's some tube unit that could be inserted between the source and the receiver. It's not that I am all that attached to the receiver, just that I was thinking that, if such a thing existed, it would probably be cheaper than buying a preamp and a power amp.
My guess is that I would need both a preamp and a poweramp (or an integrated unit). I don't need both preamp and poweramp to be tube and I don't need a huge array of glowing tubes to make me feel good. My guitar experience has shown that even one or two tubes can make a substantial improvement in tone and, while I'm sure you could do better than that with an army of tubes, at the kind of price I'm thinking about, a few tubes are good enough.
So I suppose I have three basic questions:
1) Am I right with my assumptions that I will need to ditch the receiver and get a dedicated preamp and power amp?
2) Is getting a halfway decent tube preamp and a poweramp (poweramp would probably be SS) feasible in the low hundreds price range with a willingness to buy used gear?
3) Any recommendations on what units I should be looking at and where to buy? (P.S. I am morally opposed to buying Behringer gear, so please recommend other stuff.)
Thanks in advance.
