SVS recommends in their owner's manual after setting the sub output to 1/4 to 1/3, "Set the receiver's subwoofer output signal no higher than -5 dB initially." Then, "We recommend you turn down the reciever's subwoofer output level before you significantly lower your sub's volume/gain control. This helps keep distortion sent to your SVS to a minimum. You should not be set (sic) this control much lower than -5 dB however, since some adjustment may be needed to fine tune levels later. If your subwoofer reading is still too high, then turn down the sub's amp volume a little with each run."
