Hi:
I have a Yamaha Avantage RX-A1060 as my main AV Receiver.
I'm running 7.1 speakers :
- 4 Klipsch R-14M.... 2 = Surround Back, 2 = Surround Side.
- 1 Klipsch R-12SW = Subwoofer.
- A Klipsch R-25C = Center Channel.
- 2 Bose 301V 8" = Left and Right. (Soon to be replaced by 2 Klipsch R-28F)
I have a SONY ZA-3000ES A/V receiver I'm not using.
I want to use the SONY as a External Amp or Preamp or Integrated Amp (I'm not sure the term) to run my left and right speakers only. (Soon to be Klipsch R-28F :^))
According to by Yamaha RX-A1060 manual (page 27)
When connecting an External Amp:
They recommend using power amplifiers that meet the following conditions:
• With unbalanced inputs
• With volume control bypass (or without volume control circuit)
Soooooo, my questions are:
1. What is an "Unbalanced input" and why do I need it?
2. What is "Volume Control Bypass" and why do I need it?
3. Does the SONY ZA-3000ES have: "Unbalanced Inputs" & "Volume Control Bypass"
4. Is there a way around it?
5. Which input do I use on the SONY ZA-3000ES receiver.
6. What Sound Field do I use on the SONY ZA-3000ES receiver.
Thanks you,
Wil Thomas
http://download.yamaha.com/api/asset/file/?language=en&site=usa.yamaha.com&asset_id=67385
https://docs.sony.com/release//STRZA1000ES_2000ES_3000ES_install_EN_ES_FR.pdf
