jburrows said:
I was looking for some help on home wiring.
j,
Are you trying to connect composite video plus left and right audio between the stereo and TV?
If so, you should use 6 conductors: 2 each for video, right channel, and left channel. The centre RCA sockets at each end of each signal cable must be connected together (this wire is usually referred to as "positive", or "+"). Likewise, the outer RCA rings at each end must also be connected together (this wire is the "negative", or "-" conductor). Do not try and ground this wire unless you know what is going on inside your stereo equipment.
It is also important to try and maximize the separation between these cables and the AC wiring whenever possible to minimize interference.
What is this "standard 3 core cable" you are talking about and how long is the cable run from the TV to the stereo?
Also, if you have a question unrelated to any current threads, try posting your own ... you'll get a much better responce.
