You can see your ipod interface on your TV screen...
I have the Yamaha RX2700, and with the Yammy ipod doc, I can pull my ipod display up onto my screen.
On the Yamaha receiver remote, select the source that reads "something"vox/dock. On the right hand side of my remote is a swiitch on the side of the remote with three choices "source" being the middle one, "amp" being the top, and I forget what the lower of the three is, but it doesn't matter becasue you don't use it for this. Select "Source", the middle notch.
Then, on the lower half of the remote, whrer the 4 arrows and center button are, is a button that says "display". Hit that, and it will activate the ipod display on your tv screen. There you have asccess to all your content, songs, artists, playlists, etc, and you can scroll through it all.
I remember a long time ago a guy here said he had issues with the display timing out after 20 seconds or so, and because of that he could never scroll through his content, but that's a function of setting your ipod back light timer to the longest setting.
If for whatever reason the video content doesn't play, choose a different iput source for your tv.
