R rnatalli Audioholic Ninja Jul 2, 2007 4,050 0 113 Dec 10, 2009 #1 Hi all, What's a good, relatively inexpensive set to replace the one that comes with the iPod? I need something similar that has the microphone built-in also.
MinusTheBear Audioholic Ninja Aug 20, 2006 3,559 0 113 Dec 10, 2009 #2 Are you looking for ear buds like these? http://stereotypeaudio.com/store/index.php?cPath=26&osCsid=04eb744b0f7989803598c7b81934dfb4
dkane360 Audioholic Field Marshall Mar 19, 2009 1,677 0 36 NJ Dec 10, 2009 #3 http://www.klipsch.com/na-en/products/image-s4i-overview/ or http://www.klipsch.com/na-en/products/image-s2m-in-ear-headset-with-mic-overview/
BoredSysAdmin Audioholic Slumlord Aug 21, 2007 15,616 0 113 New Joisey Dec 10, 2009 #4 rnatalli said: Hi all, What's a good, relatively inexpensive set to replace the one that comes with the iPod? I need something similar that has the microphone built-in also. Click to expand... I own Etymotic Research HF2 Headset and they ROCK !!! Since intro price dropped from $180 to under $130 and they worth every penny. They got the most studio reference sound as it gets in iphone/ipod headsets ever...... you can get em here: http://www.amazon.com/Etymotic-Research-Earphones-Headset-Compatible/dp/B0012OP7HE/ref=sr_1_1?ie=UTF8&s=electronics&qid=1260474528&sr=8-1 P.S: For all complainers about lack of bass - Just learn to get a proper seal and you'll be amazed by sound quality !
fightinkraut Full Audioholic Oct 5, 2009 301 0 0 Upstate, SC Dec 10, 2009 #5 I would suggest the Ultimate Ears TripleFi 10vi phones...here's the description. From what I've read they should outdo the HF2 earbuds handily. And...conveniently enough...I have a pair for sale! Only $150 shipped for you, brand new...
R rnatalli Audioholic Ninja Jul 2, 2007 4,050 0 113 Dec 11, 2009 #6 The Klipsch look like they might do the job. Thanks all!
BoredSysAdmin Audioholic Slumlord Aug 21, 2007 15,616 0 113 New Joisey Dec 12, 2009 #7 Notice that Kliptch would control volume on iphone 3g or ipod touch 2g
G georgeMac Audiophyte Sep 11, 2009 7 0 0 Dec 14, 2009 #8 Sennheiser headphones Personally, I don't think you'll go wrong if you pay a bit more and go for sennheiser headphones - the quality is superb in all regards.
