Do you work on a noisy environment? If you do, it is imperative that you protect your hearing at all times. Do you like music? If you love music, then here is a very good choice for you. Meet the Tough Sounds Hearing Protection Headphones with Bluetooth & Radio from ION Audio.
These headphones will protect your ears and let you enjoy your favorite tunes at the same time whether you are on the job or out it. They feature Bluetooth technology, so you can stream music to the speakers, or talk on your smart phone. Do you enjoy AM/FM program material? Not a problem! You can use the built-in AM/FM Radio and you're set to go. But how about noise reduction? According to the company, the Tough Sounds headphones reduce the external noise reaching your ears by 25dB. They are very comfortable and light enough for extended periods of use, so you can use then everyday without problems. It also features an adjustable headband to provide better convenience and comfort.
The equipped personal audio system consists of a built-in AM/FM Radio which offers twenty presets but if you prefer your own tunes, just stream your music from any Bluetooth device and you are ready to go. And as we said earlier, the built-in microphone is fully compatible with your Bluetooth smartphone, so you can stay in contact with your family, friends, or co-workers.
But, what about the battery? These headphones feature a lithium-ion battery that will keep them operating for roughly 20+ hours on a single charge. This design offers convenient controls that are simple to operate, including an oversized volume knob. The 1/8" stereo input can accept an audio signal from nearly any source for enhanced versatility. And the best of all, it won't break your bank account. What more could you ask for? So there you have it, folks. If you are searching for a new pair of protection headphones, check them out before buying anything else as these just might be the ones for you. What do you think?
FEATURES:
- All-in-one hearing protection and personal audio system.
- Headphones offer 25 dB Noise Reduction Rating.
- Wireless audio streaming from Bluetooth devices.
- Built-in mic for smartphone compatibility.
- AM/FM Radio with 20 station presets.
- Lithium-ion battery offers 20+ hours of use.
- Auxiliary stereo input (1/8 inch cable included).
INCLUDES:
- Tough Sounds
- USB Charging Cable
- 1/8 inch cable
- Quickstart Guide
- Safety & Warranty Manual
Price: $89.99
