I would skip Deftech and Klipsch in your price bracket. You can do a lot better for the money. I would skip the Onkyo receiver as well, unless you can add some kind of room correction of your own, like
Dirac. Onkyos room correction equalization has taken a real dive. I would go with Marantz, Denon, Yamaha, or Pioneer instead. As for speakers and subs, I would be looking at a
Reaction Audio system for a relaxed budget, or a
Hsu system for a tight budget. That will blow away almost any setup from Klipsch or Deftech. You will really want two subs, not one. I would go with bookshelf speaker fronts. Do not get a conventional horizontal center speaker.
For a cost effective setup from Reaction, I would be looking at 3
CX-10s for the front stage, and 8
axis 5 speakers for side surrounds and ceiling speakers. I would be looking at two
Reaction Gamma 15 subs in that room. That setup will get you to THX Reference level easy in that room. If you want to beef that up, replace the Gamma 15s with
Gamma 18s or
Gamma 21s if you have a very sturdy house.
If you are not needing monster output levels and want to save some money, I would get a
Hsu package. From Hsu, I would be looking at 7
HB-1 speakers for the front stage and side surrounds, and 4
HIW speakers for the ceiling speakers. For Hsu subs, I would be looking at two
ULS-15 mk2s. That will be a very good system, it will get loud and sound great, although it won't have the dynamic range of the Reaction system. If you want to beef up the Hsu system's dynamic range a bit, use three
HC-1s vertically with rotated horns for proper horizontal dispersion. Also add one or two more ULS-15s and use them in a near-field placement. That will rock you pretty hard. Ask Hsu for a package discount if you decide on a system like that.
