Adam
Adam
Nice! Makes me wish that I had some audiophile friends. In my crowd, I'm considered the audiophile. :)
They'd have to run the test and compare things like their TV speakers to my home theater set-up. Heck, if I couldn't tell the difference, it would be worth the $100 to find out!
rnatalli
Same here. I hate those annoying phone calls from people who accidentally switched the input on their TV and panic that their TV is broken.
Adam
Adam
Hee, hee! I feel your pain. :)
On the flip side, I have a buddy who almost always has me and the pooch over for dinner anytime he buys anything new for this home theater. New TV? Dinner. Tivo? Dinner. Moved and can't figure out how to hook up the VCR? Dinner. Well, you get the point. Thing is, the guy is a brilliant engineer. He just has decided not to invest any effort in to figuring out how to hook up A/V equipment because he can always just call someone to do it. Doesn't bother me. His family is nice, and the food is good. :D
F
fmw
Rule # 1 The recording must be made correctly. When more than 2 microphones are used in a stereo recording, you're snookered. All the King's horses and all the King's men cannot unravel a mix. Another term often used in audio is coherent. It becomes a physical impossibility to create a coherent stereo illusion when more than one mic is used for each channel.
Not so. In fact a good mixing engineer can create an even better stereo illusion with multichannel close micing. One doesn't need to unravel a mix. One only needs to listen to it. There are some bad multichannel mixes for sure but there are some brilliant ones as well.
Rule # 2 The electronics in the system play a surprisingly small part in creating the illusion. It takes a wretched power amp to totally screw things up. It is not necessary to spend vast sums of money on exotic thermionic based units. Also, the crossover, assuming it's not a total dog's breakfast, has little to do with recreating the illusion of an image. (see Rule #4).
I would go further and say imaging results primarily from the recording, secondarily from speakers and their interaction with room acoustics and the electronics have absolutely nothing to do with it.
Rule # 3 A conventional pair of front firing loudspeakers cannot recreate a natural stereo illusion. It always sounds like a sophisticated public address system. I suppose the continued success of front firing units is due to the proliferation of PA systems wherever you go. A "live" jazz event isn't really live when everything is squeezed through a PA system. Hell, even the opera is now mic'd since most of the citizens expect things to be "loud".
The fallacy here is that he wants two mics and still wants a 360 degree soundstage. It doesn't work that way. If you go to a live rock event you are listening to, you guesssed it, a PA system. If the aim in a live acoustic jazz performance is to capture the room acoustics along with the instruments then that is a funcion of how and where mics are placed and how well the tracks are mixed.
Rule # 4 The dirty little secret of the recreating stereo illusion with a loudspeaker is: 360 degree dispersion at all frequencies into a solid angle. When a two way sytem is used the woofer and the tweeter must be snuggled as close together as possible. Both units must exhibit 360 degree disperion at all frequencies into a solid angle. To achieve this task the drive units are forced to behave in this fashion. One need only look at the detail of an omnidirectional microphone to see how it "receives" it's signal. A grid is fixed over the capsule forcing it to receive from all directions. At the other end of the chain we simply turn the thinking inside out and "broadcast" the signal by forcing it to disperse into a solid angle. Many speakers will have drive units on different faces of the box firing six ways to sunday. This won't work. It may sound a bit more "spacious" but since the drive units are too far apart and there is not a solid dispersion pattern at all frequencies due to lobe effects, we end up with yet another PA system. A full range single drive unit suffers the same problem. When mounted in a conventional front firing fashion the effects of a discontinuous signal launch of all frequencies will get us back to PA land. A single drive unit firing upwards and then forced to launch its signal into a 360 degree angle at all frequencies will work. The bad news of course, is that a single driver will always trade off frequency extremes - this is true no matter how it's mounted. Any talk of the basic "monkey coffin" type of loudspeaker having great imaging is nonsense on stilts.
Nobody said Hi Fi had managed to capture the live performance with perfect accuracy. There are and will be imperfections in the techology. Mr. Morris would do well to concentrate on enjoying the music rather than getting all hung up on the technology and the equipment like the audiophiles he chides.
WmAx
WmAx
It is interesting to note that I have never heard more realistic playback, than when playing minimalist mid to far field recordings made on 2 or 3 mics, played back on omnipolar speakers. Mapleshade strictly uses this recording method, and it is better than any multi-miced close-field mixdown I have heard in terms of realism. Mapleshade's only problem is the fixation on using noisy analog recording on tape with no NR - causing a constant low level hiss in all of their recordings.
-Chris
Seth=L
Seth=L
Not absolutely nothing. I once had a KLH receiver once that would defeat this argument (at least in a "electronics make no difference" debate). Assuming the electronics are competently designed and manufactured as well as meet the demands of the speakers there should be no significant difference among components.
Alex2507
Alex2507
Since buying a new TV I have had a couple of those calls from my girlfriend. I don't really mind because amongst other things she cooks ..... :D
