This is my first post on AH --but I have decided to start moving off of AVS. Question is in the re line: Is this just a colossally bad idea? Can it work?
I already have the A3-300 and it works (or will work once I get the plate amp back). I am thinking of upgrading the subs in stages -- starting with one new sub (either the Rythmik or SVS), and then getting a second down the line. But for now pairing it with what I have (which seems to do a decent job).
Room specifics: I have a dedicated home theater room that is windowless, dark and relatively tightly sealed. It is 19’ wide x 23’ long x 8’8” high. The screen wall is on the front wide wall. 15’ back from the screen wall is a 16” platform for the second row (platform is 8’ x 19’ x 16”). The platform is solidly constructed and filled with insulation, and does not resonate (at least I can’t hear it). I calculate it to be roughly 3785 cu ft of space. 3572 cu ft if you back out the space the platform takes up (I don’t know if you are supposed to do that or not).
As I thought about it during construction, I believed that the natural place for subwoofers would be along the back wall on either side of the rear row (I took pictures of the areas). So there are two coax connects (that terminate in RCA’s in the media closet) in the two back corners. The room is not sound proof – but it is resistant to sound transference. The ceiling is hung on an Auralex RC-8 channel system, all the drywall is 5/8” thick, double-layered with green glue, recessed cans have backer boxes, wall boxes have putty pads, ceiling and walls are insulated with mineral wool, door is solid core with an acoustic seal threshold. Supply and return to the HVAC system using acoustic ducting, and I have not heard any sound transfer through the HVAC. For the most part – only a small amount of sound (mostly mild hums from the bass unit) transfers to the room directly above – which is the formal living room (which no one is typically in). The room is carpeted with thick carpet and premium 10lbs pad. It is otherwise not yet acoustically treated – but I plan to do so with some DIY treatments. The left rear corner (when facing the screen), foundational corner of the house (the left wall and rear wall are foundation walls). The right wall is shared with the media closet, and the mechanical/storage room. Front wall is half foundation, and half shared with the rec room.
Equipment: I have a Onkyo TX-SR805 (which uses Audyssey MultiEQ XT for correction) and I have a Velodyne SMS-1 -- which I know is good, but cannot correct individual subs.
Let me know your thoughts.
