integrated amplifier advice needed, please!
1
123ng
I have a pair of forte', with denon receiver DRA-825R, long time ago.
Time for upgrade or add more things to make them attractive again :)
What integrated amplifier would you recommend?
Any help is highly appreciated!
1
123ng
j_garcia said:
Price range? Take a look at the Outlaw RR2150.
$1000 or less, depends on how good it is also.
The Outlaw is receiver; I am looking for integrated amplifier, or separates if possible.
Thank you.
I know it is a stereo receiver, but it has more features than any integrated I've seen, and I doubt sound quality will be an issue.
Stereo only right? If you can stretch the budget a little, I'd say the Arcam A80, but below that, the A65+ might do the trick. Both sound great. There's two used A-80s on Audiogon right now.
mike c
mike c
Integrated:
Rotel RA 1062 or 1070
Separates:
Rotel RC 1070 + RB1070 (or replace the RC1070 with RC 03 if out of budget)
N
Nick250
IMO you may well get a superior product at a given price point by buying a receiver, heck, probably an AV receiver even, because of the economies of scale. Very few integrated amps are being manufactured today while a bazillon receivers are are being sold every day so that is where the R&D budget goes. You can run the receiver in "pure direct" analog mode the signal does not get massaged. Worth consideration I think. I drive my stereo in the den with a Denon 1705 AV receiver. It's one sweet little receiver and sounds great. A pair of Paradigm Mini Monitors are the speakers BTW. Any way, food for thought.
1
123ng
mike c said:
Integrated:
Separates:
The RC03 has less watts handling than RC1070.
Use my Klipsch Forte for karaoking, 80watts continuous, which one will suits best, Rotel RC 1070 + RB1070, or Rotel RC 03 + RB1070, or Rotel RA 1070?
And what cables should I buy?
Last but not least, where is the least expensive place that I could buy in USA?
Your input is fully appreciated.
123ng
Will take a look of what you have stating.
Sincerely appreciated.
N
Newfiestang50
Take a look at the NAD C372, its has a very conservative rating of 150watts/ch, I have used mine to power my PSB Stratus golds which are very power hungry and rated at 4ohms and it did an excellant job. Just to give you an idea of its power, I had also tried a Adcom GFA 555ii (200watts/ch and well known for its power reserves) to run my golds and it could not power them nearly as well as the NAD. These NADs IMO are rated way lower than what is stated in the manual.
The13thGryphon
The13thGryphon
IMHO that is pure dreck! AV receivers are not likely to have the sound quality of a good integrated or separates. Today's AV receiver crams every gee-whiz doo-dah known to man into one chassis, while an integrated amp or preamp & amp combo is doing just one thing... stereo. All the fancy processing, all the additional channels, all the additional connections, etc. take away from the funds available to design and build a quality power supply and signal path. If you want good stereo, then stay away from AV receivers.
I used to own a pair of Klipsch Forte speakers, and although I loved them dearly, they can be a tad bright... especially when driven by an amp that adds a little sizzle or glare in the high frequencies. Take it from a former Forte owner, and go with NAD, Marantz, or Arcam. You will want something musical and smooth. Detail, yes indeed... but no added emphasis in the upper regions. Therefore, although Rotel is indeed a very good brand, and will work very nicely with many speaker lines... Rotel and Klipsch are not a good match in my opinion. Also, don't worry too much about the power rating. The Forte is a 96 dB efficient speaker, it doesn't take much power to make them jump up and boogie. Especially with the NAD line, which seems to have more ability than their official power ratings would indicate.
Take a look at the NAD C372, or even the C352 (which is raking in all kinds of fantastic reviews and awards). It was just What Hi-Fi's "Product of the Year". I'll have to own up to being a bit biased toward the C352. If you read my sig below you'll note that I own one myself.
The Marantz PM7200 is discontinued, but you can still find them here and there for a great price. The newer PM7001 is just hitting the streets, and good things are already being said about it also.
As j_garcia indicated previously, Arcam is also a very nice sounding line. However, they are rather more expensive that either the Marantz or NAD, at least here in the States.
Good hunting!
1
123ng
Very sorry, I over looked your post.
I am reading reviews on this one.
Appreciated for sharing.
1
123ng
Good hunting!
Your input is respectfully.
The NAD C372, and Marantz, both are integrated amplifier. Do you have in mind separated ones such as pre-amp and amp?
Thank you.
N
Nick250
If you stop and think about it, there is many, many times the money going into the R&D of AV receivers than integrated amps. You tell me, in what way is the power supply deficient in my Denon 3806 for example? Run it in stereo pure direct mode clearing the signal path of processing, in what way is the $1000 (what I paid for the 3806) integrated amp superior? I am not knocking your position or your experience. Maybe if I did an a/b on them in my den I would see it differently. Hell, the sound is mostly about speakers and room acoustics anyway IMO, so I think we maybe we are just picking nits here anyway. Be well.
Regards, Nick
Nick, no offense, but I have to agree with The13thGryphon completely. Listen to a good integrated and then listen to your 3806. You will understand. I brought a buddy over to do some auditioning and he brought his Studio 20s. He has a Denon 4801. When we hooked those guys up to my integrated amp and listened to just a few tracks, the first thing out of his mouth was "I didn't know they could sound that good..." IMO, the 4801 is a solid receiver too, but my integrated cost 1/3 the price and actually yeilds as good or better musical performance. All of the circuitry in an integrated is directed at a single purpose - music. take my 7200 for example: each channel's amp section is entirely independent of the other, basically two monoblocks in one chassis, and one huge power supply to power both of them. The receivers that do music well, aren't cheap, and there are very few receivers out there that I would choose for a music only system.
N
Nick250
j garcia, no offense but give me a little credit here. Your buddy brings his speakers to your listening room, the change in rooms, listening environment, time,etc. renders the whole point of your story as mute as I well know and I have to think you do too.
Nick
The13thGryphon
The13thGryphon
Regards, Nick
You're right Nick. There is indeed many times more money going into R&D on AV receivers... but the vast majority of it is going into surround modes, processing and decoding capabilities, on-screen and front of box displays, set-up procedures, and paying for royalties to be able to put those cute little Dolby Digital, DTS, and THX logos on the front panel... most anything except the QUALITY of the sound... especially in terms of STEREO sound.
On the other hand, manufacturers making integrated amps and separates are putting their R&D money into how to design the best power supply, how to design the best audio circuitry, how to minimize distortion, how to get the best SOUND for the dollar.
I do not say this to put you down or to make you unhappy with your Denon. AV receivers do have their place, and many people love them. However, for true stereo sound, they just don't cut the mustard.
Try this, take a look at the power supply in any mass market AV receiver. Note the size, number, type, and brad of the filter capacitors, note the size adn type of the primary transformer. While you're in there, take a look at the number of output transisters for the two primary channels (no fair counting the output transistors for all those other channels).
Now take a look at an integrated amp costing roughly 2/3rds of the price. I can almost guarantee that the filter caps will be more numerous and/or larger, that the transformer will be at least the same size (for just 2 channels, instead of 5, 6, or 7), and that the output transistors will be higher quality and more numerous. Those are the things that will impact the quality of the sound produced... and that's just the start.
There are any number of other items that would tend to give an integrated the advantage over your AV receiver: typically shorter and more simple signal paths, typically higher quality relays and volume controls, typically higher quality and closer tollerance resisters and capacitors, fewer (or no) IC chips (I.E., use of discrete parts), etc., etc. I can't say that all integrated amps have all of these advantages... but many do, and there are a goodly number that will have all of these advantages and more over the typical AV receiver.
If you really take the time to listed to a decent integrated, and compare it directly to an AV receiver operating in "pure direct" stereo mode... I have no doubt whatsoever that the integrated will trounce 90% of the AV receivers on the market.
N
Nick250
Ok, I can keep an open mind on this. Lets take this to the next step then. What would be an example or two of the integrated amps that would sell for two thirds the price of my receiver and provide superior sound. I will keep an eye open for them and do an audition if possible and report back my findings. Since I paid $1000 for the 3806 that would put us around $650 - $700, maybe a bit more since the $1000 for the 3806 represents a $300 discount.
Regards, Nick
mike c
mike c
Im not saying these sound better but ...
the Rotel RA1062 costs 635 USD over here ...
the Rotel RA03 around 540 USD
but Rotel has a higher end int. amp in the RA1070
Having no doubt is not evidence that there will be audible differences when levels are matched, and bias is controlled for.
Do you have such evidence? Or just the usual audio stuff.
While it is nice to discuss this and that, credible evidence would be better.
