Integra Research RDA-7.1
Dlweninger
Hi everyone, first time posting long time lurking. I have a quick question. I happened to acquire a Integra Research RDA-7.1 from an original owner, it’s in mint shape. I made the purchase for two reasons, 1. Gene’s review, 2. $500 price. I feel it is a great upgrade to the Marantz SR7013 internal amplifiers. The question I have is in Gene’s review or anywhere on the internet I can’t find the power rating with all channels driven. I understand that isn’t that important because the likelihood of all channels demanding at the same time is not likely. Would anyone happen to know what the all channels driving would be and what would you compare this amp to in modern amplifiers?
Gene's review is the only one I see. That review said it tested at 188w vs. the manufacturer's rating of 150wpc. The spec says 150w, all channels driven. Ultra 2 certification should mean power will pretty much never be a problem.
As you said, an ACD rating is not really that important or informational. The amp is only rated by Onkyo for 2ch driven in any case and don't see any bench test that did an ACD test. A bit more powerful than your Marantz, but not by tons (maybe a 2 or 3 dB advantage). If working well the price isn't bad, tho. From glancing at Gene's review it seems it's made by ATI so you might check out other amps of similar rating they make.
