I didn't really expect it, but it comes as no surprise since you are the proud owner of an AV8003.
I believe the mid to top end receivers and preamps are all built to the same standard.
Please read this, and give me your opinion of it.
http://www.samsontech.com/products/productpage.cfm?prodID=1699
That's all fine and well, but I strongly feel this is a misconception. Proper isolation and filtering can and does reduce the affects of these potential problems. Cheap receivers commonly have these problems, however Marantz receivers and many others are designed and built competently enough that this is not a problem. His and your views, in my belief, are slanted.
Would you mind putting a receiver like the Marantz SR6004 on the bench and test it under the same conditions? I'm not discounting the performance of the AV8003, I'm discounting it's cost to benefit ratio. It's a great piece of equipment to be sure, but I believe the mid to high level receivers offered by Marantz offer similar to parallel performance.
I don't run into problems with most receivers either, and I've not read anything to indicate that the Marantz receivers are temperamental or unstable. Since they share design concepts with the AV8003 I would expect them to have the same stability in operation. I fail to see how adding an amplifier into the chassis would have any affect on that in any way.
Even if Docks has a high level of interest in the tuner section of whatever unit he gets, I am pretty sure they'll be similar.
If I didn't think the SR5004 or SR6004 could relay the signal in a linear "acoustically neutral" fashion, I wouldn't be recommending them.
With your sound system, I don't doubt this for a second. The amplifiers you have can dish out some serious power, and your speakers, well..... I've not heard them, but I'm sure they sound great.
I think 3D is a dumb technology as well.
I think you've made your point, and I see the merit in it. I simply don't agree that a receiver is significantly different in terms of preamplifier performance compared to a similarly designed and manufactured preamplifier.
