Integra 50.1 to CDR Recorder
W
watsonville
Awsome piece of equiptment. Made delivery and partial hookup. I am looking to hook up my CDR recorder. It will be hooked up to the Tape in and out for Analog. The digital feeds will be CD Player with a Coax Digital Out to the Integra's Coax Digital in. The CD Recorder portion will be a Coax Digital Out to another Integra Coax Digital Input. The CDR has a Coax Digital Input but the Integra does not have a Digital Output. Niether a Coax nor an Optical. What are my options?
Adam
Adam
Do you want to record anything on the CD-R deck except for CDs? Perhaps you could just connect a digital output from the CD player directly to the digital input on the CD-R deck.
What model of CD player and CD-R deck do you have? Alternatively, you could let us know what digital inputs/outputs both have.
W
watsonville
Thanks Adam. The CDR is a combo unit consisting one side to play CD's and the left bay to record CD's. It does not record MP3 nor any other media format other CDR or CDRW. In other words DVD-R will not work. The make is a Harmon/Kardon model CDR 20. It is designed to have the Digitals to go directly to a AV Reciever ie. Integra DTR 50.1
W
watsonville
Yes I can take another output from a CD player or another device to the Input of the CDR. Alternately could I use a Y-Cable so I dont have to go behind the cabinet all the time to change out. Or is the a converter from analog to digital for multiple hookups. And the CDR is a Harmon/Kardon.
