Infinity/SVS Setup Question
Jacob129
Would the following setup work? SVS SBS-01 (5.1) System + 2 Infinity Beta 50's. Basically 2 Beta 50's(L/R) SCS-01(Center) and 4 SBS-01 Surrounds, PB12(SUB)
If not what floorstanding speakers would best fit with the svs sbs-01 system. Around 1K-1.5K for the pair
captiankirk28
Well the MTS-01 would work good with what you are asking, it would keep everything the same SVS. They are $1499.00
I don't think they will recommend you to go with the SCS-01 and the MTS-01s up front though, for the same reason you wouldn't want to go with the Beta 50s and the SCS-01 - timbre match across the front. For the surrounds, you can get away with a little bit of a mismatch, but across the front 3 the transition will tend to be a bit more obvious.
Jacob129
In a second room (HT), whats the best speaker set for a 13x18 room. Approx 1500$ total for this room.
jcPanny
jcPanny
Floorstanders
If you want floorstanders for the front, AV123 has a few models in the $4-700 price range including the X-sls, X-mtm, and the new X-statics. They come in satin black or with real wood veneer.
