Hello all,
I just picked up beautiful pair of Infinity SM 152’s. They are in near mint condition in their original boxes. After placing them on my family room carpet I noticed they are far from being stable. I ordered a set of Dayton spikes from Parts Express to solve this problem. After reading the spike installation directions I’m going to need to get inside the cabinet to install the spikes. I’m new at this so any input would be appreciated before I make a newbie mistake.
Looking at the cabinet it appears I’ll need to remove the 15” woofer to gain access. Also, while I’ve got it apart I’d like to add some bracing and damping material.
So, some questions:
1) Is there another way to get inside the case besides removing the woofer? It seems like the entire front panel should come off somehow but maybe not.
2) What kind of damping material should I use and how much?
3) Anything in particular I should know about installing the bracing?
4) Is there anything else I should do while I have the case open?
I’m going to take pictures while I’m doing this and will post them when I’m done. Thanks in advance for your input.
