Infinity ps 12 not working no lights
Paul Durham
Not sure if this istill the right place to post but I have an infinity ps 12 stopped working while playing music at a party took it apart don't look to be any signs of burning the board the stand by light does not even come on when I turn the power on the amp built into the sub fuse don't look blown any ideas
shadyJ
Speaker of the House
Staff member
I hate to state the obvious, but you need to contact infinity tech support. No one here is going to be able to help you based on that sparse information.
Check the fuses with an ohm meter. If they are blown replace once. If the fuses are intact or blw right away when replaced, take the unit to the recycling center.
Parties kill lower end audio gear and often the higher end as well. POWER KILLS.
