Infinity Primus vs. Interlude
riker1384
I may have a chance to get some Interlude IL-40's. I had been thinking of getting some Primus 360 or P362. How do they compare? They both use the metal drivers all around with a 4" mid, and one 8" woofer ought to be similar to two 6.5". I notice that the IL's have lower sensitivity. Will that be a problem when using a typical receiver?
In the past I've owned some PSB Image B25 speakers. Will I be disappointed with any of the Infinities after owning those?
ParadigmDawg
ParadigmDawg
The Primus 360's are supposed to be a lot of speaker. Andrew or Chris can give you the details.
riker1384
I'm new here, so I don't know them.
I know the 360/P362 get good reviews for the price, but on the other hand the Interlude was at a higher price point when it sold, so I was wondering if anyone thought one was better than the other.
Also I think the IL's, with their lesser depth, might fit into my room better.
MUDSHARK
MUDSHARK
No comparison whastsoever. The Primus are good valued entry level speakers. The Interlude was/is a much higher-end speaker line very detailed and second from the Prelude in the Infinity lineup of several years ago. I always thought they were similar to the B&W better 700 series floorstanders. Almost as good as the Kappa line. Almost.:)
