Newbie here. Kinda obvious since this is my first post.
I've owned an IL100S for several years now and just the other day it stopped working. I tested the power cord and it works fine. But the speaker is not getting any power (the little red/green light/dial is no longer lit up).
I'm guessing I need a new power supply. The same thing happened 5 years ago and I took it to a 'authorized' dealer. 4 weeks later and $80 less in my account, I finally got it back.
I started to unscrew the back panel, only to find that EVERYTHING is enclosed in a plastic box. I started to unscrew the several hundred screws but stopped. There are several different size screws, some of which hold the 'box' together and some that hold the various switches to the front plate.
Does anyone know which screws to unscrew? Can I just start unscrewing? The speaker doesn't work as it is now so how much worse can I make it?
I'm hoping that the power supply is easily replaceable. That is, if I can find a replacement part. So far, my google-ing has had zero results.
I really don't want to pay $15 bucks for a schematic/service manual.
How deep have I gotten myself into?
Any help would be greatly appreciated.
p.s. I did try searching the forum prior to this question but came up with zero results for both IL100S and Infinity.
Thanks in advance,
Max
