Sheep
Sheep
Wow, great find!
5 Primus 150s would be a wicked setup.
SheepStar
Wafflesomd
Wafflesomd
OMG, this is perfect for me, this is exactly what I need, awsome quality speakers for a low price (Beginner's setup)
Though I've made up my mind for the onix x-ls.
Z
Zeke0990
rjbudz said:
'Tis why I posted it. This would make a terrific system for the amount invested....great value and good listening. I'd add a sub.
im getting the Dayton one...im only 14 so i cant spend that much money on a sub so i am getting this one
Wafflesomd
Wafflesomd
Nice link Zeke.
And if you mean dayton as in dayton audio from parts express, you'll spend a heck of alot more, (btw, I live about 10 mins from it)
Z
Zeke0990
Wafflesomd said:
Nice link Zeke.
sry here it is - DAYTON SUB-120 12" 150 WATT POWERED SUBWOOFER
for some reason it puts stars in the url...idk wht is wrong but thats the one i am getting
but ya it is on ************.com for $120, got knocked down from $250 to $150, and it is on sale for $120 this week...
EDIT: here it is on Amazon.com - http://www.amazon.com/DAYTON-SUB-120-WATT-POWERED-SUBWOOFER/dp/B000C9NV78/ref=sr_11_1/102-8553451-4767344?ie=UTF8
Wafflesomd
Wafflesomd
I personally have built my own, and that sub, they may just have used a cheap driver. Knowing parts express ( And I do know them , literally) your just paying for the enclosure and amp.
I built my sub out of this: Sry, no link, audioholics must not like parts express. But its their 10" reference woofer.
MDF, beechwood veneered and with thier 100w amp (75 @ 8 ohms)
It's finely tuned and sounds perfect for my needs, cost me about 100$.
Tomorrow
Tomorrow
It is WAY cool to be 14 and own a system like you're trying to set up! Good show, Zeke.
Wafflesomd
Wafflesomd
Kinda sucks, when your 18, and you need money for things like gas, and school.
Your lucky Zeke.
I just have a sub, no bookshelfs yet, so I just use my headphones.
Z
Zeke0990
ya i am working my *** off mowing lawns and stuff, i am getting a new tv at the end of September, i will ge tthe speakers little by little but de fby the end of this year, cuz i go tmy b day in October, the tv i am getting is the Hitachi 51F59
i think it will make a nice little home theater...can't wait to show it off to my friends...i actually think i might then submit it to Ultimate Setup at IGN, and tell them i am 14 / 15 yrs old...i think they might be impressed...so ya thanks for the help guys!...btw Waffles is that sub easy to put together?...cuz i dont have much knowledge in that sort of stuff, would u b able to give me the name of the sub u r talking about so i can search for it on parts express?
Wafflesomd
Wafflesomd
Id reccomend you get an already built sub, I've built about 20 sub boxes, so I know what I'm doing ( I think!).
Z
Zeke0990
ok so that sub i linked 2 u earlier, not a bad sub right?...i mean i dont need a REALLY good sub, just something that will get the job and give me some nice bass
Sheep
Sheep
You would be better off getting 5 Primus 150s then the setup you were looking at. They're a more accurate speaker.
SheepStar
STRONGBADF1
STRONGBADF1
I have not heard these speakers in a long time, and of course it was at CC so you can't really *hear them* anyway, but WmAx says the Primus line could use some internal damping but thats an easy enough upgrade project perfect for the buget minded hobbist.(something to look forward is always good!)
http://forums.audioholics.com/forums/showthread.php?t=24989
From what I read on this fourm Five of the Primus 150's sounds like they would be a nice first or second setup. Front ported too. That will be nice for bedrooms so you can place close or on the walls.
http://www.circuitcity.com/rpsm/oid/75519/originURLEncoded/http%3A%2F%2Fwww.circuitcity.com%2Fssm%2FSpeakers-and-Subwoofers%2Fsem%2Frpsm%2FcatOid%2F-12950%2FN%2F20012898%2B20012950%2B401%2Flink%2Fref%2Frpem%2Fccd%2Fcategorylist.do/rpem/ccd/productDetailReview.do#tabs
SBF1
Tomorrow
Tomorrow
Zeke0990 said:
so i would b better of gettiing 5 Primus 150s?
I believe Sheep and SBF1 are correct...that this would be a better setup than using 4+ cc. It's cheaper, too.
WmAx
WmAx
By purchasing the Primus speakers, you probably also have a way to easily upgrade in the future if you so desire. The speakers would probably benefit greatly from some simple modifications, such as putting in a good internal acoustic damping material(the Primus 160 I checked had nearly worthless internal damping material) and some mass-loaded damping for the walls, such as Peel N' Seal or Dynamat. The end result would be substantially 'fuller/coherent' sound, a perceived comment I hear from people when a reasonable damped box is compared to a resonant one.
-Chris
Z
Zeke0990
ok then i guess i will just go w/ 4 Primus 150s and get the center channel speaker then, Thanks 4 teh advice guys!
