Infinity Beta 40 loudspeakers
L
lasuperfan1
I am looking at purchasing a pair of either infinity beta 40 loudspeakers or a pair of infinity primus360s. I was wondering if someone could explain to me some of the pros and cons of each and which would be a better choice? I can get either pair for a reasonable price, so price is not my main concern. I am most interested in getting the best quality speaker of the two.
L
Leprkon
the primus line is the entry level speaker for Infinity. the Betas are a step up.
that being said, the Primus 360's have larger 6 1/2 inch woofers and will provide more low-end fill than the 5 1/4 woofers on the Beta 40's. You have to step up to the Beta 50's to get the same size woofer.
If you don't have a sub, I would go with the Primus. If you do have a sub or you plan to get one, get the Betas. :)
markwriter
Did you ever get your advice?
I am looking at the same decision and wondered what you came up with. I hear the Primus 360's are great, but can't help but think the Beta 40's have a better parts list and therefore are a better set of speakers.
Which speakers did you get?
Thanks
surveyor
surveyor
Here's my thoughts.
The Primus Series use MMD drivers.
The Beta Series use CMMD drivers.
The Beta 40s have 2 ea. 6 1/2 " Low-Frequency Drivers vs 2 ea. 8" Low-Frequency Drivers in the Beta 50s.
The Beta Series are a step up from the Primus Series!
I hope this helps!
