<font color='#000000'>Depending upon the driver's t/s parameters you could risk damage to the speaker. If the driver's sealed enclosure recommendations are much smaller than the now sealed enclosure's volume, the woofer may reach mechanical limits very easily with little power. Basically it could be in too large of an enclosure. If the enclosure is now smaller than recommended, you could wind up with an undesired hump in frequency response with poor, sharper, lowend rolloff response. If for some odd reason it would be a spot on recommended sealed enclosure, with a qtc right around .707 you would experience greater low end response (greater meaning lower attainable frequencies) due to a smoother 12db per octave rolloff. The sub may also tighten up in transient terms as well. The negative here would be about 3db less overall volume, which is not huge, but is just noticeable. In any case, it should not be done without first contacting the manufacturer. Either to get the t/s parameters for the driver itself or see if it is possible. Usually, with a good manufacturer, what you have is about the best you can get from the setup.</font>
