QED said:
av-man:
Also would using plywood instead of sheetrock for additional stiffening help? (I know I would probably have to sheetrock over the plywood to meet fire codes)
You could go as far as to build a complete cabinet into the wall, that is very well damped and structurally reinforced with bracing, if you want optimal results.
So far as using standard box speakers, and inserting them into the walls, this can be accomplilshed, with some stipulations: (1) You muse use a shelving filter to compensate for the BSC(baffle step correction) shelving filter that is designed into all box speakers. If you don't use a shelving filter to reduce the amplitude of midrange and bass output, relative to upper midrange and treble amplitude, the speaker will sound 'chesty', 'thick', etc.. (2) The front of the speaker must be as flushed as possible with the wall, with no gaps between the speaker and wall. However, you may wish to use a thin and soft gasket material between the wall edge and speaker in order to prevent it from physically coupleing with wall(possibly leading to audible resonances).
It will probably be beneficial to add some convulted acoustic foam(s) to the wall surrounding the speakers, especially if the speaker baffle shape prevents a perfectly flush fit.
-Chris
