In-wall Speakers Definitive Tech or RBH
K
kjfox
In the process of putting together a surround sound system. I believe I will go with a Yamaha RX-2600 Receiver. I am lookign for help and recommendation on in-wall speakers. SPent quite a bit of time looking at Definitive Tech Speakers here is what I have come up with:
SUB: IWsub 10/10
Front: UIW BP/A
Ceiling UIW 64/a
Center: either C/L/R 2000 or 2300.
What do you think? Do I need a sperate amp to power the 10/10 as suggested by Def Tech?
What configration of RBH speakers would you recommend to be similar to the Deft Tech System? ARe their any majir differences between the RBH and the Definitive Tech. What are you opionions between RBH or Definitive TEch?
Thanks
AVRat
AVRat
The UIW-65, or UIW-75 if you can afford them, would be preferable to the BPs for the fronts. You will need an amp to power the 10/10 since it is a passive system.
You might also consider other manufacturers as well.
jcPanny
jcPanny
Flyfish,
This thread is almost a year old. Try to post something relevant next time.
