Hello. Would love to get some help from some folks in here if possible. I am going to try to be as descriptive as possible so please don't hesitate to ask me any clarifying questions. Summary: I have a prewired set in my home and the builder is simply no help. I have a basic 5.1 setup. I had speaker wire prewired so that I can have a left and right rear channels and I also have some speaker wire going outside for two speakers. All wires go to one source of which I was going to run out of one receiver. The Source Location: I have one source that shows two sets of cables both of which are colored in blue. Each cable contains 2 pairs of wires (black/red and green/white) for a totel of 8 individual wires. The Two Rear Covered Outlets: Left: The left colored cable is colored purple (hmmm doesn't match source...but figured out why). This cable contains a black/red speaker wire pair Right: Is colored blue (just like one of the source colored cables) and it contains a black/red speaker wire pair. The Volume Control Nob Outlet: This has six (6) individual cables and I will try to explain each the best I can. 1. This one is colored purple and contains a green/white speaker wire and is for my Left outside speaker. 2. This one is colored purple and contains a red/black speaker wire and is for the Left outlet mentioned above. 3 and 4. These are colored blue and contains a red/black and green white speaker wire and is obvoiusly going to my source. 5. This one is colored purple and contains a green/white speaker wire and is for my Right outside speaker. 6. The final one is colored blue and contains a red/black speaker wire and is obviously going to my right outlet metnioned above. The problem: Quite simply I can't figure out how I can bypass maybe the whole nob deal and just connect the speakers to enjoy my home theatre. Later down the line I can install the outside speaker set. Do I need to get a volume control and if so what kind? Is there a website that has a good tutorial on this? My second dilemna is this. Just to test the speaker wire, I connect a speaker to cable # 3 & 4 - black/red each time to see if I got sound and there was no sound. What is the deal? These are clearly the speaker wires from the source right? I hope this gives you enough information. Thanks ahead for all your help. I am really stuck here. BTW the company that installed the wires said that they can't take a liability for setting this up for me. They said they would hook up my outdoor speaker but because the receiver didn't come from them the can't guarantee sound. Oh and on top of that they estimate just to come out and setup the labor charge is going to be at a minimum $200 bucks. They also said based on how I explained this setup to them over the phone that I am not going to be able to get home theatre sound and that I should have told the builder that I specifically wanted the home theatre package. What the? Please help! Again Thanks. - StevenR
