Very long. Quite narrow.
Why would any kind of speaker diminish screen size? (I am assuming lengthwise orientation, and you better!) I mean, if it's length you have to work with, what really is the significance of moving the screen towards you a few more feet?
Look towards SeymourAV screens. Get the DIY fabric. There are two PDFs that show different methods of framing it. There, I just saved you thousands of dollars. You owe me a beer if we ever meet. I will hold you to it.
One PDF is for a simpler version. The other is slightly more complex, but still very easy for anyone who is versed with woodworking. The fabric itself is a weave.
If for whatever reason they will be inwall, and without benefit of further research, gun to my head, had to choose now, I'd go with Triad or Atlantic, depending on budget.
Any lack of bass, or midbass, capability of the speakers you choose can be worked around with subs at the front. Even a dedicated sub per channel for the front three if need be. Yeah, you might be telling yourself that you can just get larger speakers to begin with, if this the only other option, and yes, that may well be true (depending on how small, and or how much output you might need).
