In over my head with wiring speakers
Buick455
Hi from the new guy in Alberta,Canada
I have 6 Nuance tower speakers that I found in a white van on the side of the road,please don't flame me
They are (2) N-1000's,(2) baby grands N-200's,(2) N-200's.These speakers have internal amps to power the sub-woofers
The receiver is a Harmon/Kardon AVR 325
Now my problem: How do I power all 6 subwoofer speakers,I can get (1) speaker going using the receivers sub-woofer output connecting only 1 wire to the speakers low-level input
The rear of the speaker
The rear of the receiver
Thanks
ImcLoud
ImcLoud
I would wire your left and right speakers to your #7 on the receiver in the picture. Then use an RCA cable and a ysplitter and plug your #4 to that subwoofer where it says low level input. Put the splitter on the sub so audio goes to both of the, plugs red and white...
can you put up more pics of the enitre backs of each speaker
Buick455
Thanks for the reply
I do have it wired as you suggested but how do I get the other 5 speakers involved? The image of the speaker backs are the same for all of them,the speakers also have 2 high-level input connections on the underneath bottom of the speaker
ImcLoud
ImcLoud
Wire them all the same one to the center one to the l r and then the rears or surrounds. You can wire them just like the back shows too. If each on has an amplifier..
Buick455
let see if I have this right
I can wire 1 speaker into the sub-woofer output on the receiver(rca & y-splitter)
then from that speaker high level out puts to all the other speakers high level outputs
They all have amps
I just noticed the main towers only have 2 low-level rca connections on the back.
BMXTRIX
BMXTRIX
You really should post more pictures as Nuance doesn't have a website that I can find (very bad sign!) and there is little to no information to look up to ensure that these white van speakers don't destroy your system upon hookup. A few more pictures of ALL the speakers you are looking to connect would be very helpful.
