In-line Volume Control
Rusty Axle
I would like to install outdoor speakers and have the ability to control volume from the outdoor location.
An in-line volume control rated for outdoor use seems like a simple solution.
I have a Marantz SR 7011 Receiver.
Is there any risk whatsoever of damaging the receiver by installing an external in-line speaker volume control?
Why not just use a phone/tablet to control zone volume over your home network instead?
Rusty Axle
Thank you for the guidance.
There may be guests who would not have the phone app.
Regardless, it sounds like an in-line volume control is not recommended.
everettT
everettT
A cheap tablet works to give them access, under $70 and no installation required.
You let guests control the gear!? LOL never even occurred to me....
For guests who don't have the app, iPhone users can stream to the AVR using AirPlay- best way is to create a guest network for them to log on.
They work fine, but you would need to observe the power rating. Also, buy the kind that have a rotary control and make sure the desdcription mentions 'conformal coating' on the circuit board. I would use the type that DOESN'T have a bunch of resistors.
DO NOT mount it in an exterior wall of you want it to have a long, happy life- moisture can enter and cause problems.
Use speaker cable that's rated for direct burial, not zip cord with PVC insulation.
Are you using more than one pair of speakers outside? If so, this is a decent way to control each. Even If you need to adjust the relative level of multiple pairs, why would you not just use AirPlay or the Marantz/HEOS apps? Both apps allow control over Zone 2 and Zone 3. You'll need four additional channels of amplification if you want this to sound best. Don't skimp, but don't go all "I gotta have the best amp"- it's outdoors.
What speakers are you planning to use and how will they be arranged? Don't fire them outward from the house if you want happy neighbors- aim them toward the house whenever possible. It will prevent the need for extremely high power and the building will reinforce the sound.
If you want the speakers to be relatively hidden, one of the many 'landscape speaker systems' can work well- they have speakers on stakes that are similar to landscape lights and if you want bass, subwoofers are available.
That's one of the reasons I like using Denon & Marantz AVRs- the max level can be limited and nobody can go WOT.
I like that feature but more just to prevent me from doing something inadvertantly...
I do it so I won't have trouble calls for speakers that were killed, people freaked out and couldn't press the power or mute button quickly and so I don't have to explain that when two or more speaker drivers are damaged, manufacturers consider it 'abuse', so they don't usually honor the warranty. I also set the 'Power On Volume' level at 30dB above fully muted- I will never set it to 'Last'.
As soon as I saw these settings in the menu of AVRs, I used them and it's one of the reasons I still do AV/Network work for my customers, some of whom I met in 2003. I'm adding access points for one from that time, some cable cleanup on the house exterior for another from 2006 and reinstallation of equipment for someone I started with in 2008, for the 4th time. The current house reinstallation is a bit of a luxury- I don't need to search for cable paths, drill holes and pull wires- all of it is already there.
But none of them has ever called to tell me the system went WOT unexpectedly.
Yeah definitely a different situation. Those who can't setup or maintain their own system, meh.
To be fair to them, it does reqiure understanding of topics that aren't exactly mainstream info. How many people actually know that a decible is a real thing and that doubling the power doesn't make the sound twice as loud?
However, I don't see any reason to be uncritical of the US education system for not teaching science for real world applications. People ignore warnings on their car's dash because they think "it's only a little bit overheated", don't read or ignore safety instructions because they think they know better, etc.
Some don't want to deal with setup, etc and some don't bother. For them, we have a whole industry.
carlosmiguez75
Decibels aren’t linear, doubling power adds just 3 dB, not double loudness. Schools suck at teaching practical science, so people ignore warnings. If setup’s a pain, pay for help. It’s not that hard if taught righ
