In-Ceiling speakers?
jamie
greetings all
looking at some In-Ceiling speakers and trying not to break the bank -
thoughts on
Cambridge or Boston acoustics?
paradigm?
Russ or Niles
or any thoughts in general on this
thanks
jamie
Skiguy
I've heard the BA, Cambridge, and Paradigm. They all sound pretty good at low to mid volumes. The BA's (I have a set of inwalls) are not as good as the Paradigms and higher volumes. I think the Cambridge are probably the cheapest. You may also want to check out Polks.
ruadmaa
In-Ceiling Speakers
jamie said:
greetings all
thoughts on
paradigm?
Russ or Niles
thanks
jamie
The Cambridge are excellent, can't say for the others.
BMXTRIX
BMXTRIX
Also consider Sonance stuff: www.sonance.com
They are in the speaker business for in-wall and in-ceiling work offering one of the most extensive lines of in-ceiling/wall mounted gear at every range from cheap to THX certified.
RLA
RLA
Hi
Inwall and in-ceiling speakers should be chosen based on
#1 Room size
#2 Room characteristics
#3 equipment that will be driving them
#4 listening habits
#5 Installation criteria
These 5 things need to be addressed before manufacture recommendations are made.
There are many fine manufactures of in-wall speakers choosing the correct speaker not the manufacture is the key to good in room performance and system synergy
Cheers Ray
