If you are talking about a 5.1 HT setup, then I would not recommend the Paradigm CS-R60s. They are direct firing, which in a ceiling means they project sound straight down. Not good for front theater imaging. In-walls for the front soundstage would work better. If this is not an option, then in-ceilings with some sort of aimability option would be preferred. My first recommendation, for people with lower budgets, are the Polks I’ve previously mentioned. They are excellent bang/buck, on par with the Paradigms.
