jordan21
hi
i have fronts and center speakers that are 8 ohms
my surrounds are 6 ohms
my amp settings can be set at 6 or 8, what is the best for me to set this at
also.....
my lfe can be set to either just sub or sub and fronts, which is best here
thanks
bandphan
bandphan
hi
also.....
thanks
check your other post
jordan21
these are my speakers
energy speakers
specs
Nominal Impedence: 8 ohms; Minimum Impedance: 4 ohms
65Hz-20kHz +/- 3 dB
energy speakers
specs
65Hz-20kHz +/- 3 dB
I would suggest you set your amp for 8 ohms and LFE to sub only for movies. With you speakers you may want to have the sub on for 2 channel music listening.
