Hey, thanks for the replies. You've reminded me that I had heard of the Buffalo hub, but I had forgotten the name of it. I will look at that, as well as wiredhome's.
But, with AVRat's comment, I am now so confused. If with the five impedance matching volume controls I am LOSING power, than that is exactly opposite from what I thought I heard from a friend of a friend. He had just put in something similar, but I'm getting his info. third hand. He told my friend, who told me, that the impedance matching in the speaker selector somehow "chokes" off "juice" from what is available to go to each volume control. But AVRat is saying that, in essence, and I can see how it's logical, that with impedance matching happening AFTER the wire length hubbing from the home run, then each volume control is getting less - except that he is talking watts/power and I thought IM referred to ohms/resistance.
So DOES the impedance matching in a speaker selector box have the "choked" effect that the friend-of-the-friend said there was? Or is this negligable and splitting hairs, or wires?
Please know, 48 hours ago, this was all Greek-to-a-Chinaman (no offense intended, please) to me. I'm treading water as fast as I can to keep the brain cells from submerging below the level of comprehension. So don't feel bad if you give me the AV for Dummies treatment.
If it helps, my receiver is a 20-year old Pioneer SX-780, with A and B switches, with "continuous power output of 45 watts per channel, min., at 8 ohms from 20 Hertz to 20,000 Hertz with no more than 0.05% total harmonic distortion", per the manual. Of the five pairs of speakers, two pair will be on simultaneously very often, three pair on together slightly less often, four pair only very occasionally, and five pair all at once, almost never.
THANKS,
Sherry.
