gene said:
While the debate rages on with the “Cable Experts”
What debate? Did I miss something??
Gene, that AC resistance curve for the sonicwave is way off. Can you re-do it?
Great putting the meteor and sw on the same graphs..nice to see comparison.
The sw inductance is falling quite a bit faster, I presume it's internals are larger guage than the meteor's. The graph shows all 30 nH gone by 100Khz, so I believe your auto-cancel feature is having some problem at the higher freq's.
The effective dielectric constant of the meteor is 5.5, while the sw has 2.69, both at 100 hz.. I assume the meteor has different insulation?, or perhaps it's just less parallel conductors..
How's it goin? Long time no talk.
Cheers, John
