I'm trying to understand...
DT1009
Forgive me all of you accomplished audiophiles, I'm trying to decide between two receivers and need to make sure I am not missing anything basic on the role of the A/V reciever. It has always been my thought that the most important function has been to power the speaker system and distribute the sound properly. Now with HDMI connections and the like, does the reciever do anything to either improve or degrade the video signal as it goes through it? If so, what features really matter? I'd prefer more clean power over connection bells and whistles.
MDS
In general video switching in the receiver, regardless of the format (composite, s-video, component, HDMI), is purely for convenience so that the receiver can switch audio and video at the same time.
Many receivers however also 'transcode' from one format to another; ie if you have one source device using s-video and another using component video with only component video cables going to the TV, the receiver will convert s-video to component. The higher end receivers can now do that for HDMI as well so you can use a single HDMI cable from the receiver to the TV.
Normally this is all just pass-through switching (video is neither improved nor degraded), but some receivers are starting to incorporate scalers to change from one resolution to another. Some will argue, but in my book that is a feature that is not useful as the TV will scale if necessary.
