I'm at a bit of a loss here, I'm having trouble picking up one particular station on my preamp. The thing is - I have two big extendable antennas which look vaguely similar in fashion to this:
But I have no plastic base, it just has a small peg a the bottom connecting the two and I made a wood block for it to rest in and it is plugged in with one of those push on coax connectors. In total length, I'd say the antennas are about four feet long fully extended each.
Now I've tried wiggling, touching, extending and shrinking, everything short of holding onto one of them and sticking my hand straight up to get a better signal. One station keeps coming in as garble and trash - but it's a reasonably strong signal. It never crackles or hisses in my car. Yet another station which is typically weak and staticy it picks up great with no crackle. I can't listen to the channel due to so much crackle noise. I like listening to the radio from time to time and I particularly listen to this station.
So what can I do to improve the quality? The signal is coming in fairly strong on the signal meter on the front but the sound is bad. The station that is weak has one to zero bars but still has a good sound and isn't too quiet. None of this makes sense to me - any suggestions? Anything I can do besides climb on the roof and mount a huge antenna or something?
