...what would you buy?
I’m having trouble making a decision on a home theater audio purchase, so I thought it best to simply lay out the situation and hope the good ppl here will point me in the right direction…
I am looking for a 7.1 HT Speaker + Receiver setup; currently I am using the built in speeks on the HDTV and an ancient 2.1 computer audio music setup (criminal). The ‘living’ room is approx 16 x 19, but has more airwave space to fill with 12’ ceilings, an adjacent dining room adding another 10’ of width, and a kitchen adding an additional 8’ of depth but half-blocked by an 8’ wall (Sorry if that is confusing). It is a stand-alone, brick house.
My emphasis is on listening to music, but surround is nearly as crucial for movies. Budget is $1500.
Receiver – Ease of use is important, as well as heat tolerance as it will be in an enclosure. Quality is key as I hope to keep it for some time…the ability to use SIRIUS and/or stream web radio (shoutcast) would be nice, but isn’t a deal breaker. Keep it in the $450-600 range...
Speakers – Front speakers are important as I will be using it for music moreso than movies…would this make floor-standing speakers more worthwhile? I’ve been considering the Klipsch HD500 or quintet + Sub (noob picks?), then adding 2 front floor speakers for music…I’ve also been looking at the Klipsch B-20 5.1 setup…(in no way am I stuck on the Klipsch brand BTW). If you can’t tell, I have no idea which setup works best for music…
So anyways, I’ve hit a wall in my research and really need some direction from you, the HT expert. Any comments/advice is helpful and VERY appreciated. Thanks again..
