Hi there. I have a floating wall cabinet (mounted to the wall with no legs) and a 55' TV mounted just above the cabinet. The existing cables from the components inside the cabinet are run up inside the wall to the TV. However, when I attempt to run new cables through the wall, they get stuck and I need to pull them back out. So the alternative is for me to run the wires on the outside of the cabinet up to the TV, which I don't want.
So I would like to purhase a receiver, place it in the cabinet and connect everything to the receiver and use the existing hdmi cable to go from the receiver up to the TV. The problem is that I only have a depth of 12.5 inches in the cabinet.
The only options I am aware of is to purchase a small receiver, however I can't seem to find one with 3 or 4 hdmi in. Alternatively I could purchase a full size receiver, put it in my unfinished basement, connect via IR remote and run the cables up through the wall (although my preference would be to have the receiver in the same room as my cabinet).
Any ideas or suggestions? Is there a receiver that would fit into this depth that I can consider?
