I've been thinking about what modifications I could do to my Infinity IL10 bookshelf speakers that would fix my few qualms with them. I do apologize for a general lack of knowledge about what those problems may specifically be, but I'll try to describe them.
1. - They are a ported speaker. When the port is unplugged the bass is a bit exaggerated. One part because of the listening space and the other is no doubt due to the crossover/port tuning. I plug the ports and I lose a bit of the lower midrange that makes the speakers sound bigger (not exaggerated in this range). I hope that isn't confusing.
2. - The terminal mount sometimes buzz at certain frequencies at moderate to higher levels of playback. This is a rare occurrence, but distracting none the less with certain passages.
3.- An exaggerated hump around 150-160Hz and another up around 1000Hz I believe. That could be partly due to the room as well.
Right now in the current setup the system is setup as 2.0 in the nook of my apartment which opens into the kitchen and living room area. The ports are plugged and I get useful output down to 35Hz and audible output down to 25Hz. Overall this is very satisfactory to me, as I'm getting pretty much full range sound with substantial authority. Power is provided by a Niles SI-275 amplifier and the speakers are less than 4 ft apart and less so from the listening position, so basically near field. Sound stage is relatively wide and center stage is focused and not excruciatingly finite (meaning I can move my head around a bit and get comfortable without losing the "sweet spot").
The upper midrange and highs sound very good to me, mostly smooth until the material gets complex. This could be due to the crossover, the drivers, or possibly the source material. I'm thinking it's most likely the crossover.
Improvements that I would seek:
1. reduced middle midrange (which I define as around 1000Hz) which currently overpowers the midrange and highs a tad. It can be a bit shouty as they currently are.
3. Improving the high frequencies to not become muddled when the program gets more complex. If they could keep their composure with multiple layers of material that would help tremendously.
3. Getting rid of that buzz would certainly be nice.
I'd rather not sacrifice much if any extension if it can be helped. I know adding bracing the cabinet would likely sacrifice extension for accuracy. Perhaps I could line the cabinet walls with dynomat and that would possibly help. Currently it only has polyfill.
Advise or suggestions is what I'm looking for.
Thank you
NOTE: I may try to get a 2nd pair of the Infinity IL10 monitors from the second hand market for this "experiment" should it be worth my while. The main reason I chose this model as a candidate is that Chris (former Audioholic's resident) had talked to me long and hard about using those speakers in an upgrade was interested in doing. He seemed to believe they had a lot of potential. I'm not interested in turning them into some kind of absolutely insanely flat response speaker system, I'm interested in something simple that will make improvements on them without forfeiting their sonic character. They're easy and enjoyable to listen to.
