apatel25314 said:
How do you do it, there is a smudge on the lens and i am scared to wipe it
any suggestions and/or experiences
Can you tell if it is on the outside surface, inside surface, or withing the lens itself?
The outside can be wiped with soft cloth, or tissue. Inside is out of question. Back surface needs to get into it, probably in the book for lamp replacement part, maybe.
