I need your help please!
RealMFG
Alright I will start from the top. I don't know anything about Surround Sound.
That being said here is my problem:
I have a PS3. I will have an LCD TV soon. I was thinking of getting this - http://www.abtelectronics.com/product/28942.html.
Then I read that you cannot use HDMI with that receiver for audio. The receiver only uses HDMI for video. For audio, I would have to use an optical cable for my PS3. Then I read that for PS3, you can only use an HDMI wire in order to have 7.1. That being said, should I downgrade to 5.1, and would using optical instead of HDMI result in "compressed audio" (which is what I also read), and thus worsen the audio quality?
Thank you.
Seth=L
Seth=L
The HDMI inferface has more potential for audio than Toslink (or other SPDIF protocols) and can handle uncompressed LPCM from the PS3. SPDIF can only handle 2 channel PCM and legacy Dolby Digtal and DTS streams. On a budget of $500 for speakers and a receiver, you aren't likely to get all the features, and SQ you want.
mpompey
mpompey
Do you have the 7 speakers and the sub for 7.1 yet. If not, go ahead and go down to 5.1. You may be able to get better quality gear shooting for a 5.1 setup then trying to max it out for 7.1.
However, if this is going to be a hobby that you get into here's an equipment progression that I usually follow:
1. Display
2. Receiver/ Components
2. Front speakers
3. Surrounds
4. Center
5. Sub
Rinse and repeat
