I need some advice on speaker placement
Lady Phoenix
Lady Phoenix
Do you have any flexibility for moving where the TV is?
iGirl
iGirl
Like everyone else, I have no alternate suggestion for the room set up as it is - but can you re-arrange the beds? Try moving one bed 90 degrees up along the RH side and moving the second down into that same corner to form an "L", if you can. This would free up the wall on the LH side so you could center the screen, seating and audio to create a much simpler "sweet spot". Other than bunk beds, I't all I got.
N
Nick250
Ok i just got the Sony HT-DDW790 Component Home Theater System and i need help on where to put my speakers? I did a drawing on the comp to see if it would be good the green is the speaker. here is my system http://www.circuitcity.com/ssm/Sony-Component-Home-Theater-System-HT-DDW790/sem/rpsm/oid/174935/catOid/-12954/rpem/ccd/productDetail.do
Where is the main listening/viewing location? The speakers are small which ususally means more placement options.
One comment I have is that this is very basic system which you may grow out of pretty fast. If this is all your budget will allow then so be it. If not, I would go up the food chain some. For a lot of AH members, budget constraints limits how much we allocate to audio systems so one learns to live with it at whatever price point that is.
Nick
