I need help picking an actuator for a home project... no idea where to start
ErinH
ErinH
Alright, here's the deal. I need a linear actuator, yet I have no idea where/what to get.
The purpose is to lift a coffin lid for a Halloween prop. I'm guessing the weight is 35lbs MAX. Stroke would probably be about 4"-8" range.
I know what I need it to do, yet I have no idea where to find one that will do this for relatively cheap. I've checked e-bay and these puppies are at least $75+shipping... much more than I want to spend on something that I have no idea will work or not. Beyond that, I've never used a linear actuator in my life so I'm not sure what I would need to do to get an actuator to work: is it simple plug and play as far as hooking it up to home electric (110-120 VAC) and that's it? Is there a potentiometer (speed control) on devices like this or is it full open/full closed?
Any ideas where to start? Someone care to help me figure out this issue?
Adam
Adam
Erin, is this for a one-shot opening, or do you want to do it repeatedly throughout the night?
unreal.freak
unreal.freak
you could consider using an old air shock.....you know....the ones people used to use to jack up the rear of their muscle cars with. And compressed air of course.
Peace,
Tommy
Adam
Adam
I was thinking that you could use a relatively inexpensive spring system, if you're only doing it a small number of times. You would probably have to manually put the lid back down, though.
race4aliving
race4aliving
See if you might have a dealer near who used to sell those old big satallite dishes. they were rotated by a low voltage linear actuator, they may have an old one laying around.
race4aliving
race4aliving
Maybe you can find an old washing machine motor , make your self a cam shaped end for the shaft and use a hall effect sensor to turn the motor off at the end of rotation of the lobe. control the times you want the whole effect to occur with a timer.
