I need help on cleaning the NS-1000M.
Y
Yamaheart
I just got a pair of NS-1000M at the antique shop. Condition is average, and what is the best way to clean the grills on all 3 drivers? Using keyboard/computer cleaner okay? What not to use to clean them? Thank you so much.
WaynePflughaupt
WaynePflughaupt
Don't know why a vacuum cleaner wouldn't work, followed by a cloth sprayed with Windex or something similar.
Regards,
Wayne A. Pflughaupt
Y
Yamaheart
Can I take the metal grills apart to clean the inside? Can I spray windex or something similar direct to the drivers (Berrylium tweeter/midrange)? Thanks..
WaynePflughaupt
WaynePflughaupt
The best way to determine that is to remove the drivers from the cabinet. You might also try that compressed air in a can they sell for computer keyboards that you mentioned earlier.
Regards,
Wayne
